Need Help with my Knock sensor
Discussion in 'Civic and del Sol - EG and EK' started by DrAy, Mar 15, 2007.
  1. DrAy
    DrAy New Member
    K i got an 2000 civic si, i put and b18a1 Ls Vtec. My check engine is on and i need to turn it off. I went to check it out and they told me it was my knock sensor.
    I was just wondering if the 90-94 integras have knock sensors. And if it has a knock sensor, were is it located.
    Any help will help. TY
  2. eg6sir
    if you're running a vtec ecu, it'll try to find the KS.. so since the b18a/b block didnt come with them. you'll either need to chip the ecu and disable the KS or mount one on the block somehow
  3. ThatGuy4life
    ThatGuy4life The Riced Sleeper
    Albuquerque, NM
    What he said ^, get a p28
  4. DrAy
    DrAy New Member
    Yeah i an running a vtec i have an 2000 si head on it. Where and how much is it to chip the ECU.
    TY
