!!need help with rear toe in civic!!
typerhead
Member
lately i did an alignment in my 96 civic hx and the rear left toe bolt seems to be stripped b/c it is not going into place. i had it at the shop trying to take it apart but ive had no luck. ANY ONE HAVE ANY GOOD IDEAS or ADVICE!!! :worthy:
When you undo it, can you move the trailing arm to adjust it? Those bolts are a pain.
CAn you adjust it, and can you tighten it back up, that's the real question.
