need help!
ALEXBECK23
N/A boost=Turbo boost
hey guys im just about to get a Si 2000 cluster and im wondering if that cluster is gonna fit in my civic ex 93!!! thanks.....:confused:ohhh and forgot to mention that im gonna swap a B18C gsr...and im just wanna knoe if i can use the P28 with the B18c1???? because is alot better and more easy to tune!!!!!!!!!!!!!!!!
not sure about the cluster but the ecu should be fyn with the engine wiring harness that will plug in to your wiring loom and the ecu should be ok but you might want to tune it up with the b18c map on it
