Need List Of Parts To Do A Mini Me
Discussion in 'HYBRID -> EG-EK / DC' started by type_r_hatch, Jan 27, 2003.
  1. type_r_hatch
    type_r_hatch Member
    hey can someone give me a list of parts to do the mini me swap so i can get my girls hatchback running thanks
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I did this today,go to search and type in mini me,you will get a website worth of threads :D
  3. slammedb18acivic
    slammedb18acivic Senior Member
    pa
  4. hatchboy
    hatchboy Sleeves+boost=Love
    Oak Harbor/Battle ground,wa
    Hey i just got done with my mini me swap.
    1. d16z6 complete head
    2. d16z6 intake manifold (or use your existing one so you dont have to rewire)
    3.92-95 civic SI timing belt
    4. 92-95 civic ex/si plug wires
    5. d16z6 distributer or d16a6 (works with light modification)
    6. PM6 ECU or P28 ECU
    7.d16z6 head gasket,exhaust manifold gasket,intake manifold gasket and (valve cover gasket<--not required)
    8 a way to activate vtec if you arnt using a vtec ecu (switch or rpm activated switch)
    I am pretty sure that is everything.
  5. type_r_hatch
    type_r_hatch Member
    and all that i can use with a d16y7 block right
  6. type_r_hatch
    type_r_hatch Member
    well iguess get the smae stuff jus off a d16y8
  7. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    can you use a civic vx block? or would you not want to.
  8. markie
    markie Senior Member
    how much did it cost to do the mini me swap
  9. markie
    how much hp does a mini me make
  10. xj0hnx
    C.C.TX.
    Depends on the block and head and the combination of parts inside.It isn't a factory motor that you can just pull specs on from your ass.
  11. markie
    can i put a d16z6 head onto a del sol s block and if i do around how much hp will i expect outta it
  12. E_SolSi
    yes... thats what a mini-me is (a SOHC VTEC head on a SOHC non-VTEC block)
    this usually is good for 110-140 hp depending on the build... in a perfect world with the right parts you can get 160hp out of it
  13. Nerologic
    Nerologic Member
    the dist. depends on which ecu u use if u sue the obd1 ecu u have to use the obd1 dist and if u use the obd0 ecu u need to use the obd0 dist i did this a while ago but i didnt like it so i went with the complete d16z6 it was less of a pain all i had to do was swap the motors and thats it....
  14. markie
    so the 1.6 head will go onto a 1.5 block if that is so why cant i put a dohc zc head onto my 1.5 block
  15. Nerologic
    Nerologic Member
    who said u couldnt put the zc head on the d15? my firend did on a d16 which is the same but he had to do a couple of mods so i know it is possible u just have to use older prelude parts on some ish but i rather just clap a vtec head and not mod much ish....but then again just swap in the whole motor its less of a hassle...
  16. markie
    yea what about putting a d15b head that would be a good swap too right?
  17. teal_dx
    teal_dx Member
    Medina / Akron , Ohio
    hey hatchboy, did you use your modified Z6 head you were selling or a different one? If so, how does it pull?
  18. markie
    um i don't think u can mount the dohc head onto a sohc block can you?
  19. Nerologic
    Nerologic Member
    dude u can mount the zc head on ANY "D" series block u just have to get different timmng belts and ish like that what my frined did that was stong as hell was a d16z6 head on a zc block...that motor was solid and banged gears like no other d series....
  20. markie
    i asked can i put the zc head onto d15 block nothing else
