Need P30 help
reckedracing
TTIWWOP
VIP
I need a OBD2a USDM P30 to run a B16.
The list here on hondaswap says the P30 is OBD1
I have found a P30 but 1) I think its auto. 2) I don't think its from north america, meaning it won't hook up to our OBD2 diagnostic scanner and won't pass inspection.
Can someone tell me where to find info on a P30-N51?
Where can I look for a P30?
there are obd1 and obd2 p30 ecus - there a few ecu's you can run for a b16 depending on your obd and needs/wants etc.
i'm looking to run a 100% stock OBD1 B16A1 with an OBD2 P30 in an EK chassis.
I need a USDM OBD2a to run diagnostics for inspection in my state.
I found a P30-N51 in North Carolina for 375 but I think its going to throw a code = no inspection.
you'll probably want to get OBD2 components off a B16A2, like the dizzy and some sensors eh? or how are you avoiding that
the main problem with the OBD1 B16 is the crank sensor, since the OBD1 block doesn't have a spot for it
someone here gave me a great link to a write up on converting the OBD1 distributor and what wires to cross to get rid of any CEL for the crank sensor
using OBD2 injectors, and i think the rest of the sensors are in the write up
i know, i think you're the one that gave me the link
now as to where i find this uber rare computer...?
that i couldnt tell you.. i'll see what i can come up with.. look to spend around $250 for one though
