t3t4delsol
Member
ok, well I finally fired the sol back up yesterday after just rebuilding the motor and I am getting code p0453. My sol was turbo but is no longer, I put everything back close to stock, now my question is that when I was turbo I had a resistor box wired into my injectors. I talked to my tuner yesterday and he told me to take the power feed that went to my resistor box and wire it back into all of the power feeds for the injectors, which I did. but now im wondering if I should reconnect all the wires to there own power feeds, if thats what I would need to do to clear the code. I'm including some pics showing what im referring too.
this is the location of the wires in the car
also I dont have the original ob2a p28 that came in the car, I used a ob2a p2p in its place, although I dont think that is the problem, btw the car is a 97 sol si and the motor is a d16y8. I also dont have the original fuel pump in I have a 255 walbro but I cant see that causing a issue
