Need some help
91CRXSI
Member
I just finished building my h22 for my 94 prelude, i am installing a turbo and running a 3" downpipe, the only problem is that the downpipe is in the path of the front engine mount, i have heard that you can run without the front engine mount, but i am concerened about wheelhop, would installing upgraded mounts or mount inserts on the remaining three do the trick? or will i be fine without it?
thanx for the help!
Its only a guess but my guess would be with the added power of the turbo, you will want to run with all your mounts.
Thats what i was thinking, but how do you get around it?, i certainly do not want to dent my downpipe, and it interferes near the mount bolts, has anyone ran into this before?
