I'm trying to figure out why you don't think a stock map wouldn't get you around. There doesn't seem anything extraordinary about your build that would make a stock map dangerous. You are only running 9.5:1 compression, that isn't anything high. You seem to be running a pretty standard set of boltons as well. I bet you'll be fine on a stock map until you tune. I on the other hand, cannot. 11.5:1 compression does NOT like stock maps. lol. We should meet up sometime, I too am experiencing tuning woes. Went to the smog station, needless to say, my car is smoking fuel, yet my WB says it is running lean. I hope I didn't fry the lsu4. Good luck, bro. I'm in pismo beach if you are ever down this way...
