need torque wrench settings
gatto-is-alive
i need the correct torque settings for a b16a
head bolts
cam caps
rod bolts
crank caps bolts
flywheel bolts
pressure plate bolts
10x
You need to get yourself access to a factory service manual. Not only do you need the torque specs, but for most of those, there is a tightening sequence you need to follow in order to properly seat the parts. I will say that there are free FSM's out there on the interwebs. I can't post a link to copyrighted info.
gve me a year and model your engine came out of. i have every factory manual in a database going back to 1982. i can list all your specs you need
