neon pistons?
JDMB20Coupe
Powerd With 1 Cam
ive got a set of neon pistons and the bore is 87.5 the compression is 9.8. will these fit in a b20 block?
b20b stock bore 84mm you say those neon pistons are 87.5, unless you want to try the b20's already fragile ass sleeves and bore it out 3.5mm wont fit.
