I have a 96 Civic Coupe. After I swap my D16Y to a B16A I would like to upgrade my brakes. Could you please suggest a good set up for the front discs and calipers? Keeping in mind that my rear brakes are drum brakes which im going to leave as they are.
depends on budget.. if its a tight one, id got with fastbrakes too.. if not, i stay either stop-tech or brembo.. more than half, i believe, of the ultimate street car challenage, used stop-tech and results werent disappointing.. however, a stock gt-r with stock brembos did just as well if not better than those with stop tech..
Actually it is true. If you choose to only upgrade the front brakes al you are doing is making the front setup do more of the braking. If instead you choose to upgrade the stopping power on both front and rear you have increased the stopping power of the car, this also allows you some control over the front to rear ratio.
