new car or keep the hatch
Discussion in 'HYBRID -> ED-EF / DA' started by d16a6civichatch, Dec 4, 2008.
  1. d16a6civichatch
    d16a6civichatch New Member
    i need another oppinion... i am trying to buy a 2000 Honda Civic Si B16DOHC Vtec for 2900 but the only problem is it needs a crankshaft. would this be worth it and how tricky is replacing a crankshaft going to be ...sooner the reply the better =) thanks
  2. austin20110
    austin20110 New Member
    Northern Va
    how mechanically inclined are you?
  3. eastbxc
    eastbxc Custom User Title
    Kansas
    thats strange all it needs is just a crankshaft.....i would think if something on the crank was messed up there would be some other problems
  4. austin20110
    Northern Va
    thats what i was thinking also, but if he gets it and tears it down he will be able to see if something else is wrong
  5. eastbxc
    Kansas
    yeah i am just trying to point out....its a good possibility that its just not the crank that is screwed up
  6. d16a6civichatch
    ya i am pretty decent and have some expierence on my belt with cars or hondas lol but the guy told me that a mechanic said it was a crank shaft and said it would be a 1000 dollar fix which i thought that was BS . it is stock so its hard to think a crank shaft would just go out...
  7. austin20110
    Northern Va
    well it could if it was ran really hard but like east said thats not the only thing thats going to be wrong with it
  8. eastbxc
    Kansas
    well if it is true it would require a little more work than belts require.....your going to have to be able to take the whole engine out of the car then you should be able to put in a new crank.......i just do not see why there is just something wrong with the crank and nothing else
  9. 95b16coupe
    95b16coupe New Member
    ct
    regardless, a 2000 civic si shell is probably going to be more than $2900.
    first, who diagnoses a bad crank?
    second, if the crank is bad, i'm sure something else is bad.
    third, b16 swaps are cheap, if the engine is bad, you could get an $8000 for $4,000 after the swap.
    fourth, why are they selling it rather than fixing it? something should be a red flag there.
  10. d16a6civichatch
    ya i see. well if in the end it was completed it could be worth well over 2900 with only 60,xxx miles on it...
  11. 95b16coupe
    ct
    pics or link?
    my guess is that it's stolen.
  12. eastbxc
    Kansas
    i would really think about what b16coupe said.....it just sounds really fishy
  13. eastbxc
    Kansas
    i just find it really strange that a honda crank would have something wrong with it at 60,xxx miles on it....there has to be something else they are forgetting to tell you
  14. austin20110
    Northern Va
    how does a crank go bad after 60k
  15. austin20110
    Northern Va
    east beat me to it lol
  16. 95b16coupe
    ct
    it's a big difference between hiding and forgetting.
  17. austin20110
    Northern Va
    sounds like they are hiding
  18. 95b16coupe
    ct
    too many red flags. stay away
  19. eastbxc
    Kansas
    haha i got lucky and beat you to it......thats what i cant figure out
  20. eastbxc
    Kansas
    forgetting hiding....pretty much there is something else wrong besides the crank but i would agree it sounds like they are hiding it
