NGK G-Power gap size
flydex28
Ok so here is the issue... I need to change my spark plugs and got a new set of ngk g-power (BKR6EGP) plugs from NAPA. These are the same plugs I had before. The problem is I dont know the right gap size for them. the honda book i have says to never re-gap platinum plugs but the only gap size it gives is way bigger than these plugs come with. The guy at the local NAPA here is useless and is trying to tell me these plugs arent even listed for my car... even though their website says differently. I have a 92 civic with a B16SIR2. Does anyone know what the right gap for these plugs are?
well thats the number i saw on napas website too i believe.. it kinda wierded me out how the book was saying to never gap them. and on top of it the plugs in the engine now arent gapped that much... not sure what thats been doing for me. These plugs come out of the box at about .035 and need to go to .052. that seems like a big amount.
I'm not sure about g-powers (never heard of it), but i know on the R platinum and iridium they come pre gaped and you are under no circumstances to re gap them. Before or after they have been used. If you gap them they will foul out or crack pretty much immediately. I have experienced this on my OBD0 B16a. NGK recommends that if they are not the proper gap to take them back or toss em.
Great now im lost again.. I did purchase the ones napa recommended.. the regular style plugs but the entire plug itself was much longer than the platinums so I returned those. its funny because every plug in the box is at .035
just get regular NGK plugs... that is what is recommended in hondas manual.
NGK Spark Plugs USA
FAQs - Spark Plugs
Q: Do I need to set the "gap" when installing a new set of plugs?
A: Maybe. A spark plug part number might fit hundreds of different engines from many different manufacturers. Although the NGK factory will set the gap to a pre-selected setting, this may not be the right gap for your particular engine. The incorrect plug gap for your engine can contribute to a high rate of misfires, loss of power, plug fouling, poor fuel economy, and accelerated plug wear. It is always best to check the gap against the manufacturer's specifications. If adjusting the gap on fine wire or precious metal plugs such as platinum or iridium be very careful not to apply any pressure or prying force to the fine wire center electrode or insulator as they can be damaged. The gap should be adjusted by only moving the ground electrode.
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
If you have any questions, please contact the NGK Sparkplugs Tech Staff:
Tech Support - Click here
The manufacturer of your vehicle, the company that produced the aftermarket products you've used and/or your mechanic are all additional sources of gapping information if you've modified your vehicle.
Grab these up if you are looking for .052
NGK PFR6G-13
Laser platinum pre gaped to .052
and for the shits and giggles of it i also ran a 95 del sol VTEC with the B16A3... it also is listed as taking a 0.052 gap
then because i was bored i ran through just about every B and D series Honda or Acura engine and they pretty much all take either 0.044 or 0.052 gaps
That's the main thing though, how is NAPA selling him a plug that is well under where it should be.
I'm not sure where I read that you shouldn't gap them.. I'm gonna have to dig around. I guess if NKG says you can then it shouldn't be a problem :ph34r:
i heard the whole dont gap them thing too... but when i started noticing that fresh out of the box they were not even remotely close to the correct gap i looked a bit deeper and sure enough found that even NGK recommends gapping them to make sure they are correct
i assume the do not gap thing is some old wives tale from back in the day that has been passed around so long it is just accepted as fact without anyone actually checking up on it
:shrug2:
i always check mine and adjust them as needed
And thats what i was wondering.. in know pregapped doesnt mean a whole lot.. just seemed like a big difference.
Well i read it in the chilton manual... cant remember if it was in the service manual. Im waiting to see what the ngk "tech" says.
LOL i watched the training videos on the ngk website and it says its ok.. he even gaps an iridium plug.
Well you ve been a big help you guys... thanks for the info.
