Nissan suspension
Discussion in 'Other Vehicle Discussions' started by NissanNiNjA2nd, Aug 27, 2004.
  1. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    So for the past week or so I have been researching the suspension for pulsar... so far I have figured that I can put things from the B13 chassis on to the N13... so that is plus... basically it means I can Use the SE-R springs and struts for me... :D
    So after reading through other things I have noticed that I will probably be using KYB or tokico, basically because they are readily available to me
    Ive read that B is using 8/6 on his del sol... is that in kg/mm... err what...
    in lbs I have noticed a lot of people going with 400/350 for serious Auto-x.... seems a little stiff to me.. I was think more along the lines of 350/300....is that too low... this car will be a VERY serious auto-x car... thats all I am building it for... 1/4 can eat a dick, straight line doesnt take shit...
    What do you think for spring rates and other suspension stuffs, AND WHO???!
  2. phunky.buddha
    Dallas / Fort Worth, TX
    You can't compare the Pulsar/NX's spring rates to a Civic... the shocks mount in different locations. My old roommate has a 96 SE-R, and he went with 300lb/in up front and 200lb/in in the back with a custom TrueChoice coilover setup. It was plenty stiff- comparable to a stiffer spring setup in a Civic.
    The 8/6 or whatever numbers you see people posting up are kg/mm figures. Each 1 kg/mm is equivalent to 56 lb/in.
  3. TurboMirage
    i would go with the kyb agx struts.
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    ^^ thats what I plan on getting for the 240...
