Nitrous Help
Discussion in 'Forced Induction' started by sihatchback_RL, Jun 7, 2005.
  1. sihatchback_RL
    sihatchback_RL Senior Member
    Anybody know how to install a Venom Nitrous system. How much should i shoot on a GSR with mild cams?
  2. formby
    formby learning in progress
    look for instructions on their web site.....as far as how much to spray...it depends on alot of factors....start low 30-450shot and buy bkr7e plugs (6097 is the item # @ advance auto parts) or bkr7e-11 these are just pregaped and not vpower.....
  3. sihatchback_RL
    I'm running on Denso Iridium, that should be fine right. Here's my setup:
    JDM GSR
    Skunk2 Stage 1 Cams
    Skunk2 Cam gears
    Comptech 4-2-1 Antireversion Headers
    Greddy E-Manage on P30
  4. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    No, Iridiums burn too hot. You need a 1-step colder plug. I don't know the exact part # tho. as far as the shots go, depends on if it's a wet, dry, or direct port.
  5. HollowJDM
    HollowJDM Senior Member
    hows your emanige workin for ya? my friend got one for his turbo teggy and in the booklet it sais it can control injestors up to 100% bigger then stock, but call greddy. Kengi will tell you "oops typo, its only 10%." but other than that it tuned well. we tuned it better in a garage then it was tuned off the dyno.
  6. sihatchback_RL
    The E-manage is awesome. I had Capital High Performance tune it for me. So i should go to gold or platinum plugs? I'm running dry nitrous, this is a first and i don't want to mess up my motor. all i want is at least two car lengths improvement. I'm running 13.7 now.
  7. B16RacerN2NR
    Moving back West...
    well a dry 30 shot with colder plugs and slightly retarded timing will be more than what your looking for. I don't know the part # for 1-step colder plugs, just ask around, someone on here knows.
  8. formby
    :wtf: did any one read my post....the bkr7e is what you need....i just installed those on my rex with a 60hp wet shot....7 is one step colder for most dohc vtec motors and 2 steps for non vtec dohc motors
  9. sihatchback_RL
    well i bought the darn kit today. Looking forward to burn that crx that smoked me by a hair and yapping his mouth.
