no change in throttle power
Discussion in 'HYBRID -> ED-EF / DA' started by mustang67n, Aug 15, 2006.
  1. mustang67n
    mustang67n Senior Member
    ok.. just got my SOHC ZC in my 89 DX and i did the MPFI swap before..
    but i have an odd question.
    when i get on the throttle, there is NO change in performane when comparing anything past 1/4 throttle other than noise from the engine.
    the further i push the gas, the engine kinda humms..
    its the same whether i push on the pedal, or on the linkage on the TB.
    sound familiar to anyone?
    im thinking maybe my throttle position sensor is still wired backwards from the MPFI swap?
    im not throwing any codes.. and im running a PM6 ECU
    any ideas?
  2. formby
    formby learning in progress
    have some one step on the gas pedal, you look at the TB and see if its opening all the way.
    if it is, then its okay its just slow.
    what kind of tranny is on it ?
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    P.S. Do the gas pedal/trottle body thing with the motor off. (I know this seems obvious, but some things just need to be said.)
    How fast are you going when you press the gas pedal from 1/4 to full throttle? If you are sailing along at 100mph its going to get louder but won't pin you to the seat or anything.
    same if you are going 30mph in 5th gear.. The motor will get louder but won't take off like a rocket, it'll take a while.
  4. mustang67n
    yeah.. the TB is opening all the way.
    lol. its just as fast as its ever been.. i just thought it was wierd that there was no difference between 1/4 adn full throttle..
    btw, this is at ANY time in any gear.
    oh.. and its a dx 5 speed.. w/e comes standard in the '89 dx *shrug*
    hmm.. maybe its time for a lil spray.. just for shits. lol
  5. F22HB
    F22HB New Member
    haha, ya go with the spray just because its america and you can...plus a button with NOS on it would be sweet. If I had money, I'd be on the bottle too!
  6. mustang67n
    lol damn right!
    now.. to save $$ and think up a good way to hide the system.. fun fun! lol
  7. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    I'd buy an Si tranny instead.
    Gearing is probably whats making it feel sluggish...
  8. reikoshea
    Dallas, TX
    ive had a similar problem before...does it feel smoother at part throttle than it does at WOT?
    It was my coil causing the problem.
  9. mustang67n
    yeah.. an SI tranny is on my list too.. probably get that before anything else.
    yes, its MUCH smoother at part throttle
  10. reikoshea
    Dallas, TX
    i had the problem you are describing too...couple weeks later, the fuel pump went out. i replaced the fuel pump, that wasnt actually what went wrong, the main relay blew. so after replacing both, the problem went away.
    im just noticing how many problems my prelude has had...i need to dump this bitch.
  11. mustang67n
    allriight.. so i was checking with the other problem i had (the backfire through the IM) and i think both problems were one in the same.. i advanced my timing a bit (using the dizzy) and BOTH problems are practically GONE!
    there are no more 'pops' from the IM and i actually HAVE power with the throttle pressed all the way! i actually have the dizzy adjusted as far in advance as it can be.. but its working great so i'll let it be for now lol.
    leaving my house, i smoked the tires lol. i didnt even have to drop the clutch like i used to have to.. i just put the pedal to the floor and the tires broke! of course.. taht could be because my tires are near bald.. (getting new ones on saturday) lol
    anyways.. YAY :)
  12. jlicrx
    jlicrx Senior Member
    Colorado Springs
    sounds to me like the camshaft timing is off - you shouldn't have to advance the distributor as far as it will go to get it to run - distributor should be right in the center of the slots, if the camshaft is correct
  13. mustang67n
    yeah, thats why i want to go at it with a timing light when i can..
    i know i got the timing belt on there correct ( had to do it about 3 times lol) but its probably still off by a few teeths
