did a engine swap on my 88 crx hf took out the 62 horsepower hf engine and put in a d15b7 blew it up with nos now put hf engine back in now no spark checked wire connections crank angle sensor igniter main relay and fuses all good but no spark coming out of coil and no light on in the ecu when you turn key on tried 3 different ecus all do the same please help :sad:
