No Spark???
Discussion in 'Civic and CRX - EF' started by sleeper1.6, Jan 17, 2009.
  1. sleeper1.6
    sleeper1.6 Member
    I have a 91 Civic with a stock engine, and I am having a problem with getting it started. It will turn over, but Im not getting spark with a new distributor. Could it be the main relay?
  2. austin20110
    austin20110 New Member
    Northern Va
    is everything hooked up right?
  3. sleeper1.6
    sleeper1.6 Member
    Yep I made sure of that. A distributor is easy to put in. It only takes 20 mins. or so.
  4. chadcharb
    maple valley, Wa
    i just finished puttin a new stock motor in my 91 and had the same problem and it turned out to be a small ground wire under the distributor, kinda next the the starter. you might check for something like that.
  5. George777
    George777 ^^ Likes Bewbies
    With your mom
    The ground on the t-stat is a common one people forget to hook up.
  6. sleeper1.6
    sleeper1.6 Member
    Ill check it out. Thanks.
  7. Ethan
    Ethan Well-Known Member
    When you turn your key on dose the check engine light come on for a couple seconds and then go off?
    I forgot it once it took me 2 days to figure out what was going on.
  8. sleeper1.6
    sleeper1.6 Member
    I think it does. I dont know iv always been out side of the car when my friend tries to start it. The guy who had it before us did some weird wiring. Its every where.
  9. 91hondacivcdx_man
    91hondacivcdx_man for the love of hondas
    salt lake city utah
    why don't you try the ignition control module that could make it turn over but no pick up and start u got 1.5 liter right
