No Spark
Eros2180
Ok guys, i just put the d16 in and cant get it to start up. i checked for fuel, good, checked for spark, a no go.
I checked the hot wire going to the dist. and it gets 12v, so i went and bought new dist. and plugs. swapped them out and still nothing. Ive checked fuses and relays, even replaced the PGM-FI relay. nothing
Anyone have any suggestions, this is getting frustrating
I also checked the 3 grounds--Therm ground, valve groung and tranny ground..all good
Im not sure if i missed a relay somewhere or what.
The TPS is on the manifold but i have no plug and wire for it and Vtec is not wired yet
Sorry can't help i'm going through similar issues after F22A to H22A swap in my prelude, if anyone has any suggestions i'd be keen to hear.
ok guys, for future help, the Crank Sensor wire ( i believe was yellow with colored stripe, dont remember exactly ) goint into Dist. plug had a loose connection.
Fixed the wire and for the first time she fired right up!
