not quite a stall but falls on throttle down.?
Discussion in 'General Tech and Maintenance' started by danherman, Sep 16, 2015.
  1. danherman
    danherman 206Raincityed7
    Seattle
    My tps is working fine. Well 4.6 so normal. Possibly iac or throttle body. When drivingbruns just fine but when put in nuetral or coming to a light it drops low, falls on face more less. 250 rpm maybe. Its a ls vtec obd1 have integra throttle cable. Very long for ef but didnt make an issue past year cars a 91 ef
  2. Matts96HB
    Matts96HB . Moderator VIP
    Does it idle fine when sitting still? Do you have to pedal it to keep it running?
  3. Briansol
    i can't remember... was it you who was having distributor problems too?
    the eld (electronic load detector) wiring is intergrated in there too and will cause rpm dive like when you turn on ac if it's not functioning properly
