O.k. Guys, Who's The Smartest?
sohcslammer
I had heard that a sweet setup was CTR intake cam and ITR exhaust cam. Now I am hearing that the CTR and ITR exhaust cams are the same... Does anyone REALLY know? I'm sure that one of you geniuses knows for sure... Fill me in! :worthy:
Originally posted by luVTEC@Apr 18 2003, 12:57 AM
Hope this helps,
Honda VTEC Engine Specs
They sell the motors and can't spell it right hmmmmm......
95 .....Civic Del Sol.. V tech..B16A. .engine CA legal(Used $1350.00)f
93......Civic Del Sol...V.Tech..B16A DOHC…(JDM CONVERSION KIT... $2500.00)m
95...Civic SI.... D16z6...1.6L...V-TECH...DOHC...TRANS...ECU...(KIT $2800.00)G
Thanx guys, I guess I would just save money buying the CTR set instead of CTR intake and ITR exhaust. Is the CTR set the best to use on a N/A b18b with a b18c5 head? any sugestions?
i'm assuming this is a bare c5 head? if so, yes that would be a good setup to go with, not best, but if money is an issue, this is a great setup. make sure you get at least type r springs and retainers in there also.
