O2 sensor stimulator
Discussion in 'ECU's, Electronics, and Tuning' started by Akirazian, Oct 7, 2002.
  1. Akirazian
    Akirazian Banned
    anyone know how to build one for OBD 1 for 92-95. I just installed a straight CAT so my CEL is on.
  2. pissedoffsol
    what car do you have? i have never seen a honda o2 sensor that plugs into the car. they are usually on the manifold either before the cat, or shortly after the head/manifold meet
  3. slohnda
    slohnda Senior Member
    Sierra Vista, AZ
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    what code is it throwing because the 92-95 O2 sensor is before the cat on the exhaust manifold up high on d series and right on the collector of the exhaust manifold on the b series...
    i've never seen a 5th gen throw a code for that shit
  5. pissedoffsol
    thats what im saying-- the o2 isn't NEAR the cat...
    unless its an dx/LX and like the cat is up high on the manifold... like almost aprt of the downpipe
  6. Akirazian
    Akirazian Banned
    I have a JDM B16a SiR II in my 92 honda civic hb. I'm using my stock CX engine harness. Which i think is not a good idea. But it does plugs right in the JDM b16a motor and works properly. The only problem that the stock CX engine harness doesn't have is the VTEC, VTEC Oil pressure, knock sensor, and O2 sensor. I hooked up VTEC, VTEC Oil Pressure, and knock sensor. But the O2 sensor have 4 different wires. I dont know where the 4 wires lead to. I was told that if i use the 92-95 Civic Si engine harness. The problem of the O2 sensor would be solved. (Not sure, but does the Si engine harness have 02 sensor that can plug right into the B16a?) But it's too much trouble to take all the wirings out the engine. So i found a site that teaches me how to build my own O2 sensor stimulator. So instead i wouldn't have to change the engine harness to the Si. It's throwing out O2 sensor problem. Because the O2 sensor as of now is not hooked up.
  7. Jeef
    Jeef NO MA'AM Moderator VIP
    With the o2 sensor just add the wires for the o2 sensor instead of ripping out your harness and putting a new one in.
  8. chet
    chet Senior Member
    st petersburg, florida
    a friend of mine has done this before. i'm familiar with how to build this simple device...but he can tell you what to buy at radio shack. its like 15 dollars...
    as far as the o2 sensor, it would be easiest to add the necessary wires.
    email leon at j3rky@yahoo.com
  9. Akirazian
    Akirazian Banned
    ok ok Jeff, I know two wires leads to the ECU but what about the other two wires?
  10. Jeef
    I will get you the web page in a few days. I wont be around too much anymore, I hate my fucking job.
  11. Akirazian
    Akirazian Banned
    Thanks alot Jeff. Just post the link up. Thanks!
  12. Akirazian
    Akirazian Banned
  13. B16
    B16 Super Moderator VIP
    yay area, CA
    you need at least 1 O2 sensor, otherwise you car would run like crap. also, the only time there is a O2 sensor in the cat is on OBD2 cars/motors, which from what you said, you do not have... so this must be for your only O2 sensor? you should get it hooked up to the ecu, can you use your old O2 sensor from you old motor?
  14. knowledge
    knowledge Senior Member
    Beale AFB, CA
    I would say get a new O2 sensor. This way you can eliminate any problems that might arise.
  15. Akirazian
    Akirazian Banned
    the problem is not the O2 sensor. The wires is not properly hooked up. Thats why the CEL is on.
