crxlsvtec1221
Member
sup guys i've been doin this swap for a customer and the problem is i cant read the code that the p13 ecu is putting out due to me using a jumper harness and when i use a stock ecu it doenst put out a cel so im thinking it may be the jumper harness im using or a sensor that is not being connected the only sensor that i have not connected was a black soleniod with two vacuum outlets located above the fuel rail the vacuum for the fuel pressure regulator is also connected to it. so i was hoping some had this problem previously or if someone knows how to check the codes from a jumper harness (obd2a to obd1) thanxs
