OBD2 intake manifold, throttle body, injectors, distributor, alternator, wiring harness, ecu...
if the car isn't obd2 you're gonna have to either 1. adapt your engine harness to the obd2 motor and get an obd1-obd2 jumper, or 2.put an obd2 in-car harness in your car.
you're also gonna have to cut-and-splice some wires (some of the sensors on the block probably wont plug in), and you'll also need to buy an obd2 IAT sensor (since it was on the intake rather than on the manifold like the obd1)
