Hey everyone,
I swapped in an OBD II b18c1 motor into my 93 Civic EX. I recently failed my BAR appointment due to the fact that I am using an OBD II intake manifold instead of one off an OBD I gsr. After installing the new manifold, I ran into some problems with running vacuum lines and a coolant line.
My problem with the vacuum lines is that one hoses from the EVAP control canister has no where to be connected to. It is supposed to be connected to a nipple on the throttle body, but it is missing on the OBD II throttle body I am using. Would there be another place to hook this hose up, or would i need to get a different throttle body?
Also, my problem with the coolant hoses is that on the OBD I intake manifold there is an extra nipple for a hose to go on, and it is supposed to connect to the throttle body. But because i am using an OBD II motor, there is no nipple on the thermostat housing that connects to the hardline next to the breather pipe. Could I use a T-fitting to connect all three lines together?
