obd question.
b16crxb16delsol
i have a obd1 ls engine and an obd0 b16. if i put the obd0 dizzy and use the obd0 pr3 ecu will that work on an ls engine?
but will the b16 stuff work on the ls engine? i have 2 complete engines so i have all the parts. im just wondering if the b16 stuff will work on an ls engine. like will the ecu and the distributor work on an ls engine or will it run shitty.
it will run but probably not all that great seeing as how the b16 computer isn't designed to run a non-vtec ls. it would be throwing all sorts of codes. this is also assuming like B said that everything matches.
build an ls vtec. use the ls block, the b16 head and tranny and computer and eletronics. obd0, and way more pwoer than either.
