obd0 b16a into a 90 teg
97CTR
My buddy swapped a first gen b16 with a pr3 ecu into his teg and he wired in his vtec, but he says there is no vtec. I have yet to go and take a look at it. So if anyone has done this swap before, what do you need to run for vtec on this setup, (vtec solenoid, oil pressure switch, etc.) what are the ecu pinouts and does the obd0 have a knock sensor?
yes you need to wire knock, vtec oil pressure, vtec and prob the 2nd o2 if you car doesnt have 2 already
yuor freind probably just fucked up the wirering somehow
:werd: i have a 90 teg with a b16a swap, and we had to wire in for the other o2 sensor. however, my motor is obd1, so we had more wiring work...
but the vtec oil pressure, knock sensor, vtec solenoid ALL need to be wired up.
