Obd0-Obd1 conversion problem
Discussion in 'Civic and CRX - EF' started by csanchez, Dec 11, 2011.
  1. csanchez
    csanchez New Member
    I am trying to convert my obd0 b16a in my 89 ef to obd1 and in the process of doing this, I no longer have any spark. I just bought a new distributor (td-44u) thinking it was the problem but it didn't change anything other than throw a code 15. I figured out that I had a open in the white wire running to the ignitor. I am using a p28 that I bought from Mr. CG. The only code I have now is a code 20 which I believe is for the ELD. I double checked my jumper harness to make sure all the wires were going to the correct places which they were. I double checked the resistance value of the coil which was in spec. I changed the ecu out for a known good ecu and still no spark. I am just getting really confused where to go with this. Any help would be greatly appreciated, thanks
