OBD1 Ecu converion
Discussion in 'ECU's, Electronics, and Tuning' started by SolReaver, Nov 10, 2002.
  1. SolReaver
    SolReaver Senior Member
    Can a obd1 p75 automatic ecu be converted to a manual ecu relatively easy? If so how do i go about doing that.
  2. pissedoffsol
    it involves soldering and stuff....
  3. E_SolSi
    i think the conversion you need is called eBay... its pretty easy .. you put your ECU up on there and sell it to someone then you take the money you recieve and convert it into the right ECU... its really a pretty simple process... i can get you more detailed instructions if you wnat them ;) hehehehe
  4. pissedoffsol
  5. SolReaver
    LMAO!!
    Yeah i kinda figured it would involve that ;) If someone knew the actual wires to solder or what to do...
    and esolsi- thats what im going to do...theres an obd1 ecu that i need but its an auto, and its like 15 bucks with 10 hrs left
    So the final question is- can it be done???
    :huh:
  6. pissedoffsol
    its not wires- its chips and capacitors
  7. Jeef
    Jeef NO MA'AM Moderator VIP
    Its one resistor that needs to be soldered. Your car will run with an auto ecu but the cel will be on. I can find out which resistor it is. I believe its on the hondata website.
  8. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    between the ROM and the side of the ECU are a number of jumper resistors labelled with RP. remove RP17 and install a jumper across RP18.
    that will convert a usdm p75 obd1 ecu from manual to auto
