alright here's the deal i got a good deal on a eg civic w/ a gsr swap so i went against recommended obd choices b/c i drive a 96 civic hatch cx. I know this can be done, and still be able to pass emissions still i was just wandering if someone could give me a complete run down on the parts i will need, not including the normal mounts and iacv mods. I have a very good idea (such as obd2 crank sensor, timing gear, and timing cover, obd2 alt, obd2 distributor, believe i can use my d16 injectors)but please be as thourough as possible so i can get this project underway. i really appreciate any help you guys or girls could give me.
also and not nearly as important as the first half comes the more part. i will be building this engine before it goes into my car considering i need to tear it down a bit anyways to change head gasket and and the crank sensor, the question i have it considering a good tune, rods, and pistons, how reliable would a turbo setup be without sleeves/ or how high can i push HP. is 350-400 out of the question?
