obd1ls injectors
smashed4thgen
i am looking for replacement for a bad injector for a obd1 ls integra injector...what other injectorswill ge the same as stock for a b18a1(hope it makes sence)...
240cc is the size... not sure if b18a's use peak/hold or saturated style though...
if you have a resistor box, get peak/hold
if not, get saturated
other LS injectors will work, as well as non-vtec d16's. right now im running d16a6 injectors on my LS. they are both the same size, but u can find civic injectors for way cheaper. if u are going nitrous, get some 450's
