if is homemade you should check it first.otherwise its a plug and play.I have one on my 97 civic with a p30 too.I got the wirring conversion of ebay for $75 and works perfectly.
i was looking at the donor car by the way donor car also 98 hatch been smashed in the rear anyways two plugs left inside the vehicle on green one gray i know the green supposed to be there but the gray has some of the wires out of the green plug i looked at the convertor harness and the gray one plugs into it not the green guess i do have to swap some wires any advice greatly appreciated
