JDM do not use a Evap Purge Solenoid that runs to the charcoal canister. This means the ECU doesn't look for it. I do not think it would make it fail the sniffer test but not having a Evap Purge on the Intake Manifold wouldn't technically pass the visual inspection. But they may not look for it. If you need to run one....its not too involved to attach one to a JDM manifold. But you would need a USDM ECU, Evap Purge and engine harness (or seperate plug at Evap ran to the ECU) to make it happen.do the jdm pcm's have readiness tests? i know the emissions regs are not the same but will a jdm pcm pass an obd2 emissions test? if not can i use a usdm pcm on a jdm motor? such as a jdm sir2 (or 3, i forget which one is obd2) motor and '99 si pcm. i would rather use the jdm pcm though.
