wisemansoji
is there any diference in the wiring in a 98gsr vs a 2000 gsr, or are the harnesses the same
Originally posted by wisemansoji@Oct 28 2004, 04:49 AM
if I use stock harness why do i need to change the distributor and injectors to obd1,..........is it because the plugs don't match............if I change the plugs I can use all the obd2 stuff on the engine
[post=408503]Quoted post[/post]
