odb-0 to odb-1 cross over
Discussion in 'HYBRID -> ED-EF / DA' started by Dark91zc, May 29, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    what do i need to change to make my engine bay odb-1???
  2. brian11to1
    brian11to1 Senior Member
    are you asking about an OBD conversion? basicall you go here and search for obd conversion harnesses. then you get OBD1 injectors, ECU, dizzy and do the converison.
  3. Dark91zc
    Corona,CA
    what is the difference in odb-0 injector to odb-1 injector
  4. brian11to1
    OBD0 has an injector resistor box and they are peak and hold
    OBD1 doesnt have a resistor box and they are saturdated.
  5. JKOBD.com
    JKOBD.com Wiring Guru
    Engineer at the Source
    Yes. Also, FYI, you do not need to convert to OBD1 injectors when you go to an OBD1 ecu setup. You can retain the pre-obd (OBD0) injectors and the resistor box and it will be perfectly fine.
    Jason
    www.JKobd.com
  6. brian11to1
    I knew that, but I didnt know the details. plus wouldnt it be beneficial to convert to the OBD1 injectors?
  7. Som1Dies2Nite
    Som1Dies2Nite Member
    When goin to OBD-1...the OBD-0 injectors can still be used if the resistor box is used..Am I right? If I decide to use OBD-1 injector, then they can be wired direct?
  8. brian11to1
  9. ripperbone
    ripperbone angry bear
    Oklahoma
    if you use obd1 injectors then yes they can be wired direct
