odb-1 dizzy rewire 2 odb-0
Discussion in 'HYBRID -> ED-EF / DA' started by Dark91zc, May 26, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    can i redo the plug on on a d15b vtec dizzy that is odb-1 and put the white plug from a d series dpfi plug. (lacking money :( ) or can i use a dpfi dizzy or zc dizzy on that head
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    OBD1 distributor will not work on OBD0 engine - you need OBD0 distributor - DPFI distributor will not work on MPFI engine - DOHC ZC distributor will not work, as it has no Cylinder Position Sensor - only options are to modify mounting of Si or HF OBD0 distributor or (best) convert it to run OBD1 using OBD1 injectors, OBD1 distributor, P28 ECU and OBD1 to OBD0 conversion harness
