Odb1 b9 pinout starter
Discussion in 'ECU's, Electronics, and Tuning' started by autox19, Oct 16, 2017.
  1. autox19
    autox19 Member
    Lansnig, Michigan
    Probably an easy question, but I googled and I couldn't find the answer. Because the engine is going into a different car, I used the starter circuit of the fiat. Not a problem. Starts, but instated thinking, is this pinout to tell the ecu the car is in start mode? Should I branch off the fiat starter signal to this pin?
    Odie
    Fiat x19 b16
