oem camber adjustment
mikesphat
Yo how do i measure and change the camber on my 91 hb? i have stock suspension peices all the way around. the driver side tire is getting eaten on the inside. thx
You need a camber kit. No Civic from 88-00 had any kind of OEM camber adjustment. If you had a 2001+, you could adjust the upper mount point of the strut by adding camber plates, but you can't do anything like that on the older (and better) double wishbone suspension.
id say swap'em, and slow down.
there is not reason stock peices should throw your camber that far off.
What u want man its stock ill take pics of the three dead tires i have of it. So if i go get an alighnment they wont be able to fix this without a camber kit?
No, because there's no camber adjustment built into the suspension on your 91 hatch. You need to add it if you want to have the ability to adjust your camber.
