oil change...please read
Discussion in 'HYBRID -> EG-EK / DC' started by Rjs4490, Sep 30, 2009.
  1. Rjs4490
    Rjs4490 New Member
    can someone please help me out...i have a 99 gsr w/ ls tranny....im doing an oil change tmmrow...what kinda and type of oil do i need or should use....as well as oil filter
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    use 5w50 and an oil filter for an isuzu rodeo. works great, vtec hits hard.
  3. efhondakid
    Akron-Canton, Ohio
    Didnt you see that he has an LS tranny? A Rodeo filter wont work with the LS trans.
  4. 78civic
    78civic Junior Member
    NW MS, Y'all
    I wouldn't use that heavy of oil. You get 'intra-fluid-friction' that actually makes you loose power because it's harder to move around/thru. Like having a 5gal bucket of mud, trying to mix it with a stick.
    If you can, find some Amsoil and use the 0W20 or 30. I've been selling/using it for over 13yrs and it hasn't let me down yet. And usually you can go 3-5x longer before changes.
    Honda still recomends motor oil in the manual tranny's right?
    Use a 10w30 in there also.
    EF-kid.. What does the trans have to do with the oil filter?
    I've used the longer filters for the acura V6's that give more volume and no leaks.
    What's this about the Rodeo filters?
    E
  5. efhondakid
    Akron-Canton, Ohio
    LS gve him a smart ass comment so I figured I would too. I use Penzoil 10w30 non-synthetic and OEM filters, and yes 10w30 in the manual trans as well.
  6. LS_VTEC
    NJ
    lmfao I LOVE ITTTT
  7. eg6sir
