oil flange
Discussion in 'Forced Induction' started by Ignorant import guy, Nov 14, 2006.
  1. Ignorant import guy
    Ignorant import guy Senior Member
    where is the best place to find an oil return line flange for the td40 turbocharger...searched ebay already
  2. igotnothin
    igotnothin New Member
    harford co MD
  3. Ignorant import guy
    will a flange from any other type turbo fit a td40
  4. igotnothin
    harford co MD
    no the distance between the bolt wholes is the key. typicaly the actual drain and feed will match, you just need the corect distance between the two bolt wholes.
  5. pissedoffsol
    i have no idea what a td40 turbo is....
    but, email stan:
    mailto:sales@fast-turbo.com.
    he is the fitting king.
  6. Ignorant import guy
    basically it's the smallest turbo...made mostly for d16..i only bought it because a guy i know was selling it and he hooked me up with a kit but he needed the flange or didn't have it or something
  7. 96prelude
    96prelude Senior Member
    Searcy Ar
    i know what a td04 is.
  8. Ignorant import guy
    do you have or know someone who does have an oil flange...i will pay more than it's worth plus shipping...i really need one
  9. TunerToys
    TunerToys Junior Member
    igotnothing is right, the key is in the distance between the bolt holes on the drain flange. The most common sizes are 38, 44, and 50.8mm. Measure these dimensions, and then decide if you want to use a threaded pipe fitting, or AN type fittings. We can hook you up with either style for any of the sizes.
    Couple of pics...
    AN Type for braided steel lines...
    NPT threaded style for barbed fittings and such...
    Craig
  10. TunerToys
    Just a quick follow up...
    Did you get the info you needed from the above post? Let us know if you have further questions.
    Craig
  11. Ignorant import guy
    yea...i bought the flange i needed from you guys a few weeks ago..thanks for your help
