oil gauge sensor mounting location
Discussion in 'General Tech and Maintenance' started by micrometer50, May 22, 2005.
  1. micrometer50
    micrometer50 Junior Member
    Ok, so i bought an oil temp and pressure gauge with my car, and it really didn't give me clear instructions as to where to mount the sensor. I have just installed an oil filter relocation kit, so it would be really easy for me to stick the sensor where the oil filter used to be (the part where the oil comes out from the block). Would this work? And if Not, where would be a good place to stick it?
    thanks
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    It should have a T-fitting with it. What you do is unscrew the oil pressure sending unit from the back of the block (1-pin sensor close to the oil filter), screw in the T-fitting, put the oil psi sending unit on the end of the T-fitting, and the sensor for the gauge on the part that sticks out of the T-fitting.
    Thanks to ImageShack for Free Image Hosting
  3. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    great pic....(civicious).....lol
    Looks good.......................
    yeah..You can also get the t-fittings from Home depot...if you dont have it...
    HOME DEPOT is your friend....lol
  4. 92CHB
    92CHB Senior Member
    Easthampton, MA
    Or get on of those adapter fittings from stealthmode.com for $20 :thumbsup:
  5. Estorvito
    Orlando FL
    woahhh..20 bux...wow...Thats expensive man...home depot has it for under 2 bux......
    I'll get the part number for ya tomorrow.....
  6. civicious
    Houston, TX
    Yeah, that's INSANE to pay that much for a damn t-fitting...the gauge should have come with one though...
