formby
learning in progress
so i keep leaking oil from the oil pan....so i bought a new one and it still leaks.....i'm guessing its the block....every mourning my damn dip stick is between both holes.... i hate it...
how can i fix it....? with out removing the block that is...
two gaskets? honda bond? what?
also..
.when i'm driving and i go to down shift or when i decelerate then acelerate fast...i hear/feel something knocking agaist the floor board by the clutch pedal.. could it be an axle.....it looks a little crooked... axles intermidiate, shaft and spindles are from a 90 teg...on a 91 crx
also..
