Oil Line Restrictors for turbos
Discussion in 'Forced Induction' started by integramic, Apr 10, 2004.
  1. integramic
    integramic Member
    I have just seen a forum on Oil Line Restrictors for turbos? How do you know if you need one? Is it by horse power? Thanks.
  2. pissedoffsol
    a restricter is used to lower oil pressure going to the turbo, mostly when the oil is cold.
    if you have an oil press. gauge, you will notice, that at start up, the pressure is up in like the 50s-60s, but once warm, and at idle, 10-15 psi is normal.
    the turbo seals don't like a lot of pressure- they just want the lube.
    the restricter, well, restricts, the pressure.
    frankly, IMO, if you have a properly sized feed line, say -3an, i don't think they are remotely necessary.
  3. integramic
    integramic Member
    Went from oil filter to cyclinder head with a 6an then to the turbo with 4an. I have a prodrive gear and looking 550hp. Thanks.
  4. pissedoffsol
    to the head? for a vtec conversion?
    i don't know about that shit.. lol
    but the 4 is really too big. get a -3 line.
  5. [Freemantle]
    [Freemantle] Senior Member
    Vero Beach, FL
    I have no idea what your talking about. If you could explain what is an optimal setup for feed line sizes and fittings, that would be really informational.
  6. pissedoffsol
    there's 1000's ways to do it.
    but -3 feed and -10 return is common
  7. ScrapinSi
    ScrapinSi Senior Member
    for an oil feed for a vtec head you want at least -4...
    -3 is fine for oil feed on a turbo... I'm running -4, and blew the turbo seals with a 1/2" drain line. I installed a restrictor so that it cuts the pressure... works great!
  8. integramic
    integramic Member
    Know where I can find a stainless one? Let me know. thanks.
  9. ScrapinSi
    i bought an aluminum one off of a guy on h-t... look around on ebay... they pop up sometimes...
  10. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    I think I got in on the same deal. ;) $8.50 or something... Might have been $18.50... Can't remember, but it works great.
  11. ScrapinSi
  12. D See 2
    D See 2 Senior Member
    Baltimore, MD
    honda-tech classifieds own j01
  13. integramic
    integramic Member
    Tried doing a seach and still don't find one. Let me know if anyone knows anyone. Thanks.
  14. ScrapinSi
    you can use a .060 n2o jet also...
  15. integramic
    integramic Member
    Can anyone else confirm that (.060 n2o jet )?
