Oil Preasure on t04E (t3/t4)
Discussion in 'Forced Induction' started by amadeuscr, Dec 19, 2007.
  1. amadeuscr
    amadeuscr Member
    I Installed my Turbo and oil is coming out from the exhaust side of the turbo ( of course is smoking ) I think is a lot of pressure , does anyone knows how many psi of oil it should be ?
    I checked the line to the oil pan and it's fine !
    thanks in advance .
  2. danse
    danse Junior Member
    If you are running a ebay turbo you will need to run an oil restrictor type of turbo oil inlet flange.on the supply side. The other choice is to use a -3 oil line which will restrict the oil flow enough to solve the problem most of the time.
  3. amadeuscr
    amadeuscr Member
    thanks , it solved the problem !
  4. danse
    danse Junior Member
    Not a problem...good luck with getting it going...
  5. amadeuscr
    amadeuscr Member
