Oil Squrters In An Ls?
saturn_boy96
88 C1V1C 53D4N DR1V3R
Is it possible to add oil squirters from a gsr block to an LS b18a/b block?
I'm not exctly sure if that would work (pretty sure it would tho) but if you have access to a gsr block..just swap in the ls crank along with the rods and pistons in the gsr block and viola!!!!! you have ls/vtec with the head already there along with the oil squirters.
It's been done with mixed results. If you do it have someone who has done it before do it. I've heard of them being insalled incorectly and breaking off causing a lot of damage.
Have a competent machinist install them and make sure they are out of the way of the rotating assembly, and you should be fine.
