I want to to all motor LS, because I already have a LS head, and I wont need to go out and buy a vtec head, and I sort of wanted to stay away from the machine shop as much as I can, because they charge an arm and a leg because they are the only one round here, and the do work on mostly domestics, rarely a honda. I could basically install pistons, bearings, check tolerances and all that my self, i was thinking of getting sleeves, which I a machine shop basically has to do, and the PnP I cant do, and the valve job I cant do. other wise I can install valve springs, retainers, and valves my self. I just need something to really keep me busy, I get really bored, and dont like working on my car, because i dont really have much time, just an hour here and there, so working an hour here and there I can really get a lot done on the LS engine, not risking working on my car, cause if something breaks, I need to be able to depend on my car.
Basically I want to sit around and build stuff for the car and make it a drag car.
