OMG HELP, B18c1 in EK, what A/C bracket?
Discussion in 'HYBRID -> EG-EK / DC' started by stehigs321, Jul 10, 2003.
  1. stehigs321
    stehigs321 Junior Member
    Hey i recently did a motor swap of a B18c1 into my 96 EK coupe. I took out the A/C condensor and compressor because the condensor had a leak. Im finally getting around to getting put back in and it is sitting at my local honda right now. I need to know ASAP what A/C compressor bracket i need to have them order. Del sol or Si. And do i just need the bracket? or are there any other parts related to the bracket that i might need? which bolts?
    thank you guys so much.
    stehigs321@aol.com
  2. deth101
    deth101 Senior Member
    usa
    96-97 Del Sol VTEC AC bracket,new bolts and washers are never a bad idea
  3. Civic Type Sev
    Civic Type Sev Junior Member
    I agree... the Del Sol VTEC ac bracket is the one you need.
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    jdmhondaparts.com is selling a lighter version of the bracket which weighs 2.5 lbs instead of 10.
    Milan
  5. vbphreak
    vbphreak Junior Member
    You can also use the bracket from a B20
