open deck...closed deck?
Discussion in 'General Tech and Maintenance' started by mozzandherb, Jan 14, 2006.
  1. mozzandherb
    mozzandherb Senior Member
    I've seen this term pop up quite a bit, but I'm not sure what it means. As you might know I have an h22a is that an open or closed deck and what is the difference or advantages/disadvantages of the two? Thanks
  2. reikoshea
    Dallas, TX
    closed deck. Check out the block filling tech article. that article is about creating a closed deck (essentially) its cheaper to make an produce an open deck, but a closed deck allows for sleeve support...essentially making a stronger bottom end.
    Someone can add where i have missed or i am wrong, but thats been my understanding.
  3. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    closed deck
    open deck
  4. reikoshea
    Dallas, TX
    great pictures...thats what i thought.
  5. drpenguin
    drpenguin Senior Member
    Salem, Or
    so arnt honda motors open deck? if they are how arewe able to sleve them? or can any deck be sleved?
  6. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    honda manufactures open deck bottom ends, at lteast the B, D, and H series all come open sleeves. Check out the article written by Hotrex about sleeving the deck yourself or, you can buy sleeves that you weld in and the resurface the block afterwards, having a sleeved block will prevent the expansionand eventual failure of the cylinder walls due to stress caused from any number of things but in particular excessive amounts of boost
  7. drpenguin
    Salem, Or
    So what about the A20A3, C32B, F22B, K20A, K24, and the ZC's to name a few?
  8. jimboburgess
    nyc
    i figure open deck, just since it is easier to make them, and none of those enginge really need to handle great amounts of stress, but i am not sure
  9. reikoshea
    Dallas, TX
    well just so you know, H22As are closed deck. So not ALL honda engines are open deck. You ca still sleeve closed decks. You just bore the block and press in a sleeve. Not all sleeves are those CRAPPY MID sleeves that everyone is pushing. Darton sells more than that, and BELIEVE me the normal sleeves are just miles ahead of the MIDs, but you dont need a machine shop to install a mid.
  10. phunky.buddha
    Dallas / Fort Worth, TX
    Not all H series blocks were closed deck... only a small number of them (compared to the whole).
  11. reikoshea
    Dallas, TX
    oh i know that. i was just adding a lil bit of info.
  12. phunky.buddha
  13. stickyfusion
    stickyfusion Member
    hmmm... how can one tell if thier h22a is open or closed deck without removing the valves and stuff?
  14. reikoshea
    Dallas, TX
    really isnt...not that i can think of. I almost had a heart attack when i replaced my head gasket.
  15. phunky.buddha
    It has something to do with the number suffix at the end of the block code along with the year it was manufactured... all I remember is that it was a subset of H22A4s (I think)...
  16. stickyfusion
    stickyfusion Member
    if reiko has a jdm h22 then there are no #'s at the end of teh block code no? are all jdm h22a closed then?
    or are some american h22's closed as well. i have to think honda did this in some kind of oder for some reason. are h23's closed?
    fun with emotes :p
    [​IMG] [​IMG]
    [​IMG] [​IMG] [​IMG] [​IMG]
    [​IMG] damn that emote list is long yall should alphabetize or something
  17. reikoshea
    Dallas, TX
    im gonna say american h23s are open. If i blew a rod through my H23 im willing to bet they are open deck. i never took the head off to make sure, but id say it was open.
    I think 4th gen preludes were all closed (a1 american) and then the a4 was open. thats just my guess, ive got nothing to back it up. anyone know if the euro R was closed or open?
  18. reckedracing
    reckedracing TTIWWOP VIP
    NY
    NOT ALL HONDA MOTORS are open deck...
    F series are closed deck - FACT
    H22 OBD1 are CLOSED DECK - strong rumor
    H22 OBD2 are OPEN DECK - Strong rumor
    D series are open deck - fact
    not sure on ew's
    and i am quite sure B's are all open deck...
    you can sleeve regardless of whether its open or closed, it just makes it harder...
    unfortunately this makes no sense...
    rods and open vs closed deck are two very seperate issues...
    unless you had serious sleeve movement which led to your rod failure which is highly unlikely...
    H23 lower ends suck ass...
    i concur, OBD1 vs OBD2
    uh... wow, i'll just give you the benefit of the doubt and assume you meant head when you said valves and stuff...
    as far as i know there is no simple way to know if its open or closed deck...
    you could prob remove the water pump and use a mirror to see, perhaps?
  19. reikoshea
    Dallas, TX
    i made the comment about blowing a rod through the block because youd think that if there was THAT MUCH MORE metal between you and the outside of the block, it would be more difficult to put a hole in the block.
  20. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Are all F series are closed deck? Even the SOHC Non-Vtec F22?
    Very cool if so, boosting it soon so I'm curious.
