There is only 1 correction I will make on that write-up (it's a damn good one, but I am just saying). The power for the injector resistor box doesn't goto A15, it should be spliced into the remaining Yellow wire on your Cx/Dx or Lx wiring harness. I kind of forget how I did that part but if you are going to do the DPFI-MPFI swap let me know and I will check it over to confirm how it should be done. If not done properly, you can fry your injectors and wiring to them, so this step is a NECESSITY.
