p13 cutoff too soon!! HELP
Accordturbo94
Hey Whats up everyone I just did my h swap in my 94 accord! Well it seems to be running great! EXCEPT it wont let me take it past 7,000 r's! I know it shoulf be in the upper 7's before it cuts out!@ Im running the p13 ecu.... any theory on this one?
I dont get that! I hear it come one... i think is right around 6800 or so its hard to see when my tach likes to get stuck because of my ricer gauges that are coming off! Im running a vtec controller too if that makes a diffrence
Well, what are the settings that you're running on the VAFC?
VTEC should NOT kick at 6800 rpm. That's way too high. It should kick around 5200-5400. Are you sure this isn't a problem relating to your tach? Maybe you ARE hitting VTEC correctly and revving to the correct point....
